http://images3.wikia.nocookie.net/__cb20101103032428/runescape/images/4/48/Slayer_Detail.PNG Benefits of Slayerhttp://images3.wikia.nocookie.net/__cb20101103032428/runescape/images/4/48/Slayer_Detail.PNG
This thread is to Teach you the benefits of Slayer for your Pure accounts.Introduction Of Slayer:
Slayer is a Members-Only Skill which is very popular for training,and the Drops and Rewards you recieve from levelling this and slaying the monsters you unlock at different levels. The Slayerexperience you recieve from killing a monster is usually around 1/10th (10%) of the target Monsters Hitpoints. For example ; A Blue Dragon has 1100 Hitpoints , so when you kill it you recieve 107.6 Slayer Experience , which is nearly equal to 1/10th of the Hitpoints. If the monster you are attacking on a Slayer Task has been injured or is being attacked,the experience is split up ; for example: The person who gets the LAST hit recieves Half of the Experience gained,and the person who does the MOST damage recieves the other half , if you do more damage and get the last hit you will recieve the full amount of Experience.
Training Slayer:
There are various methods for training Slayer. One of the fastest and most annoying is to use a Dwarven Multicannon : http://images3.wikia.nocookie.net/__cb20110308165961/runescape/images/thumb/d/d2/Dwarfcannon.png/180px-Dwarfcannon.png
The Dwarven multicannon is a very good weapon.It hits high at any level,and is unequippable. This leads to extremely fast kills and thus fast Slayer and Ranged experience. Unfortunately there are also negatives that come with the positives. It is expensive to maintain,can break meaning you need to go to a Dwarf to get it back and gives NO Hitpoints Experience.
The Cannon costs 770.8k GP Currently from the Grand Exchange.
It fires Cannonballs http://images2.wikia.nocookie.net/__cb20110213114416/runescape/images/thumb/7/73/Cannonball_detail.png/100px-Cannonball_detail.png Which currently cost 231 GP off the Grand Exchange.
This weapon is most potent in Multi-Combat areas and is common to be used versus Dragons and long boring tasks such as Kalphites.
Expect to get flamed for using this,you only need to be on a task with one around you to know why.
Speeding Up Slayer:
Aswell as using a cannon there are other ways to speed up the process of training Slayer.
These are to use Prayer/Curses http://images2.wikia.nocookie.net/__cb20100917030203/runescape/images/e/e5/Prayer_Detail.PNG and Potions.
Protection/Deflect Prayers/Curses ; http://images2.wikia.nocookie.net/__cb20080603064959/runescape/images/0/09/Protection_from_magic.PNGhttp://images2.wikia.nocookie.net/__cb20080603064956/runescape/images/d/dc/Protection_from_ranged.PNGhttp://images2.wikia.nocookie.net/__cb20080603064954/runescape/images/6/69/Protection_from_melee.PNG http://images3.wikia.nocookie.net/__cb20100402190120/runescape/images/9/99/Deflect_magic.gifhttp://images1.wikia.nocookie.net/__cb20100319113517/runescape/images/7/73/Deflect_missiles.gifhttp://images1.wikia.nocookie.net/__cb20100319113516/runescape/images/9/97/Deflect_melee.gif
These are incredibly useful to limit the amount of damage you recieve off Monsters,meaning less time spent banking,and less money spent on food,but more spent on Prayer Potions.
Consider investing in items that give a bonus in Prayer , to slow down the Drain Rate of Prayers , thus spending less money on potions to maintain your use of prayer.
To find a comprehensive list of items to use to do so look here : http://runescape.wik...ki/Prayer_items
Use of Stat - Boosting Prayers to speed up your tasks:
Stat boosting Prayers are incredibly useful,causing you to take less damage and deal more damage more frequently,meaning you can finish the task faster giving a larger yield of Experience per hour in Slayer and the Stat you are training.
Prayers to use:
http://images2.wikia.nocookie.net/__cb20080201144451/runescape/images/b/b2/Steel_skin.gif Steel Skin : Requires 28 Prayer to use,gives a 15% Defence boost,causing less damage to be deal to you,thus using less food.
http://images2.wikia.nocookie.net/__cb20080201144536/runescape/images/2/2c/Ultimate_strength.gif Superhuman Strength : Requires 31 Prayer to use,gives a 15% Strength boost,causing you to hit 15% more,for example if your max hit is 200,this will boost your max hit to 230,and because of the higher hits you can complete the task faster.
http://images3.wikia.nocookie.net/__cb20080201144008/runescape/images/d/d2/Incredible_reflexes.gif Incredible Reflexes : Requires 34 Prayer to use,increases your attack by 15% , meaning you are 15% more accurate,and will hit decently more often,again speeding up tasks.
http://images2.wikia.nocookie.net/__cb20080524131340/runescape/images/b/bf/Eagle_eye.PNG Eagle Eye : Requires 44 Prayer to use,increases Ranged max hit by 15%,incredibly useful for tasks you range on,speeds up tasks.
http://images2.wikia.nocookie.net/__cb20100413132624/runescape/images/1/13/Mystic_might.gif Mystic Might : Requires 45 Prayer to use,increases Magical Accuracy,useful for tasks if you mage (Mainly Metal Dragons)
Missing out Chivalry and Piety - As you need 60 And 70 Defence for them - but for your mains it gives a Attack,Strength AND Defence boost in One Prayer.
http://images1.wikia.nocookie.net/__cb20100820173248/runescape/images/5/5b/Rigour.png Rigour : Requires 74 Prayer and 74 Dungeoneering and Costs 140,000 Dungeoneering tokens. Gives a 20% Ranged boost and 25% Defence Boost - Useful for Ranging on Tasks and not taking as much Damage.
http://images4.wikia.nocookie.net/__cb20100413125161/runescape/images/9/93/Augury.png Augury : Requires 77 Prayer and 77 Dungeoneering and Costs 153,000 Dungeoneering Tokens. Gives a 20% Magical Accuracy Boost and 25% Defence Boost - Useful for Maging on tasks and not taking as much Damage.
Curses to Use :
http://images3.wikia.nocookie.net/__cb20100319113511/runescape/images/0/0a/Berserker.gif Means boosted stats last 15% Longer,so you need less Potions.Requires 59 Prayer.
http://images2.wikia.nocookie.net/__cb20100319113704/runescape/images/0/02/Leech_attack.gif http://images3.wikia.nocookie.net/__cb20100402185550/runescape/images/e/ef/Leech_ranged.gifhttp://images3.wikia.nocookie.net/__cb20100625100716/runescape/images/a/ac/Leech_magic.gifhttp://images1.wikia.nocookie.net/__cb20100319113705/runescape/images/6/60/Leech_defence.gifhttp://images2.wikia.nocookie.net/__cb20100319113705/runescape/images/8/83/Leech_strength.gif Boosts stats by 5% Increasing to 10% over time,whilst draining theirs.Not worth using In my opinion so won't waste my time on it.
http://images3.wikia.nocookie.net/__cb20100320122950/runescape/images/9/99/Soul_split.gif Soul Split - Requires 92 Prayer to use ; Heals the player by 20% of Damage Dealt,smites player aswell,stacks with blood spells,incredibly useful as you don't need food if you can hit decently.
http://images1.wikia.nocookie.net/__cb20100413130943/runescape/images/2/2e/Turmoil.gif Turmoil - Requires 95 Prayer to use ; Gives Attack a bonus of 15% and 15% of Players level , Gives Defence 15% and 15% of Players level and 23% Strength bonus with 10% of Players level.
Please note you need to do Temple At Sennitsen to use Ancient Curses.
Potions to use :
Prayer Potion - Restores 2.5 times the player's Prayer level plus 70, resulting in a total restoration of 70-310 Prayer Points.
Super Attack Potion - Boosts attack by 15% Of your Level Plus 5.
Super Antipoison - Cures Poison and provides immunity for 6 Minutes - very useful.
Super Strength Potion - Boosts Strength by 15% of your level plus 5.
Super Defence Potion - Boosts Defence by 15% of your level plus 5.
Antifire Potion - Provides resistance from Dragon breath - use combined with Anti-Dragon shield against metal dragons.
Ranged Potion - Raises Ranged by 10% of your level plus 4.
Magic Potion - Boosts your Magic Level by 5.
Untradeable Potions:
Recover Special - Recovers Special attack bar by 25% a Dose , can drink 1 dose per 30 seconds.
Super Antifire - Protects you 100% from Dragonbreath - Doesn't require Anti-Dragon Shield.
Extreme Attack - Boosts attack by 5-26 Levels.
Extreme Strength - Boosts Strength by 5-26 Levels.
Extreme Defence - Boosts Defence by 5-26 Levels.
Extreme Magic - Boosts Magic by 7 Levels
Extreme Ranging - Boosts Ranged 4-23 Levels.
Overload - Effect of ALL Extreme Potions - Takes 500 Lifepoints off you,but cannot kill you - Gain 500 Lifepoints again at end of the 5 minutes - Saradomin Brews do not lower effects of this.
Summoning in Slayer:
http://images2.wikia...wolf_detail.png Summoning is incredibly useful in Slayer , there are familiars which can assist in combat via healing,carry items,boosting stats and dealing damage.I will list some of the most useful familiars to use.
http://images4.wikia..._terrorbird.png Spirit Terrorbird - Very useful - scroll replenishes run energy,useful for tasks which take alot of running to get there etc; and also stores 12 food.
http://images3.wikia...pirit_kyatt.png Spirit Kyatt - Scroll hits 250 - Good for multi combat summoning enabled areas to help you with fights.
http://images1.wikia...ar_tortoise.png War Tortoise - Beast of Burden - Carries 18 and lasts a decent amount of time (43 minutes)
http://images4.wikia...70px-Bunyip.png Bunyip - Restores a Health Point every 15 seconds and scroll (Swallow Whole) allows you to eat raw food through it - useful for camping stuff such as Waterfiends.
http://images1.wikia...x-Fruit_bat.PNG Fruit Bat - "Fruitfall" Scroll causes fruit to be dropped which you can eat - Such as oranges and papayas - also good for money making.
http://images2.wikia...-Fire_titan.PNG Level 79 Titans - Deals considerable Damage and Titan cons. scroll heals you.
http://images1.wikia...rn_stallion.png Unicorn stallion - Healing Aura heals you by a certain amount - Can interact and cast "Cure" to be cured of poison.
http://images2.wikia...olpertinger.pngWolpertinger - "Magic Focus" Scroll boosts magic by 7 - Cheap alternative to Extreme Magic.
http://images1.wikia...0px-Packyak.pngPack Yak - Best Beast of Burden - Strength XP Makes it Pure Friendly - Carries 30 Items (More than your own inventory!) and scroll Winter Storage sends items in your inventory to your bank.
http://images4.wikia...Steel_titan.pngSteel Titan - Boosts defence by 15% and Hits very hard - Like a Ranged Based Dragon Claw attack - Steel of Legends Scroll.
Please note some of these familiars give Defence Experience , and it is not my fault if you get defence in a multi way area using aggressive familiars - so do not blame me.
Slayer boosting items:
http://images1.wikia.../Black_mask.PNG Black Mask - Obtainable from Grand Exchange and other Players and as a rare drop from Cave horrors. - Needs 10 Defence to use and gives +15% Attack and Strength boost on Tasks.
http://images1.wikia...ussighticon.png Focus Sight - As above but for Ranged - Only boosts on Tasks - Available from the Grand Exchange , other players and as drops from Desert Strykewyrms.
http://images1.wikia...excresticon.png Hexcrest - As above but for Magic - Only boosts on Tasks - Available from Grand Exchange ,other players and as drops from Jungle Strykewyrms.
http://images2.wikia...ayer_helmet.png Full slayer Helmet - Provides the protection of a Spiny helmet, a Facemask, Earmuffs, a Nosepeg, the +15% attack and strength boost of an uncharged Black mask, the +15% range boost of a Focus Sight, the +15% mage boost of a Hexcrest, with defence bonuses similar to that of a Rune full helm. It is crafted from a Spiny helmet, a Facemask, Earmuffs, a Nosepeg, an uncharged Black mask, a focus sight and a hexcrest with 55 Crafting.Requires 10 Defence to wear.
There are creature - specific items but I will not list them.
Benefits of Slayer:
Finally we get to the point of the thread - The Benefits of Slayer .
This is mainly from a pures perspective so it won't include stuff for mains only.
Items unlocked from Slayer:
Broad-Tipped Bolts - Used to kill Kurasks and Turoths.Requires 55 Slayer to use. They are extremely good for Returning and training for pures - they have the exact same bonuses as Adamant Bolts - but Adamant bolts are currently ~190gp on the Grand Exchange and Broad-Tipped Bolts are ~94gp.Half price - same bonuses - you work the rest out.
Leaf Bladed Sword - Requires 50 Attack and 55 Slayer to use.Probably the best sword for 50 Attack and is comparable to a dragon scimitar,but doesn't hit as high.
Slayer helm - Provides the protection of a Spiny helmet, a Facemask, Earmuffs, a Nosepeg, the +15% attack and strength boost of an uncharged Black mask, the +15% range boost of a Focus Sight, the +15% mage boost of a Hexcrest, with defence bonuses similar to that of a Rune full helm. It is crafted from a Spiny helmet, a Facemask, Earmuffs, a Nosepeg, an uncharged Black mask, a focus sight and a hexcrest with 55 Crafting.Requires 10 Defence to wear.You need to do Smoking Kills and get 400 points to unlock the ability to make it.
As this is equivalent to a Rune Full helm it gives the best bonuses headgear-wise for a pure,meaning it is very important and is good for training and pking and is a good accomplishment to have.It is far better than any other headgear for under 40 defence,especially on slayer tasks.And it also looks cool!
Why else is Slayer good?
Slayer is also good for other things,not just the rewards.
Benefits include:
- Good Experience in combat stats
- Good charm drops
- Monsters unlocked which drop good value items and clue scrolls
- It is a well respected level to have
These are and can be found at:
Burthorpe - Turael - Low level easy tasks - Can reset tasks here,but after Smoking kills it resets your progress.
Canifis - Mazchna - Medium level/difficulty tasks.
Edgeville Dungeon - Vannaka - Medium level/difficulty Tasks.
Zanaris - Chaeldar - Medium Level/Difficulty Tasks.
Pollnivneach - Sumona - Higher level/Harder Difficulty Tasks.
Shilo Village - Duradel - High Level / Hard Difficulty Tasks.
Ancient Cavern - Kuradel - Very high level / Very Hard Difficulty Tasks.
The points you recieve from the master after smoking kills increases depending on the Master - The Higher the Master the more points you recieve.
When you reach 99 Slayer you can buy your cape from Kuradal for 99,000 Coins.
Thankyou for Reading my guide it took alot of time and effort and I hope it proves useful,I realise I slacked towards the end,and I hope you vote for it in Guide of The Week.
If you feel I can add more Post and I will try to get round to it,many thanks.
Guide made by Cal©
Edited by Cal, 27 October 2011 - 07:54 AM.
