Question to Pop on Bench press
Posted 13 April 2012 - 06:12 PM
Is that expected for my weight? Or above/Below Average?
By the end of May i want to add at least 5-6 pounds in muscle weight so that i will eventually weigh 150 Ibs.
Realistically what should my max bench press be at that time?
| Corrupt Pures | Elder | Corrupt Since 09' | #Clan-CP |
"Be miserable. Or motivate yourself.
Whatever has to be done, it's always your choice."
Retired:
@High Council
2009-2012
Posted 13 April 2012 - 06:20 PM
Posted 13 April 2012 - 06:25 PM
Retired:
@High Council
2009-2012
Posted 13 April 2012 - 06:28 PM
http://fc05.deviantart.net/fs70/f/2012/033/3/d/signature_van_der_vaart_by_kaiser97-d4oewqz.png
Posted 13 April 2012 - 06:29 PM
Edited by Pure King170, 13 April 2012 - 06:30 PM.
Posted 13 April 2012 - 06:40 PM
Guest_AlexWAAR_*
Guest_AlexWAAR_*
Posted 13 April 2012 - 07:35 PM
You can slowly increase bench press weekly,Let it be dumbell or barbell(my personal preference is now dumbell bench,it focuses on my stabilization muscles and less pressure on shoulders compared to as to barbell)..Try making your range 8-12 reps because i assume you have no spotter...If you cannot do more than 5 reps,you are doing way tomuch and put that shit down. If you can do more than 12.Add a bit more.So realistically your rep range can be 7-11.The next week or 4 days (w.e the amount of rest days till you hit it again,im assuming 3days-weeks time) Try to out beat your last performance by a bit by trying to go up just a little.You will slowly get stronger,just dont slack trying to do same weight every week
Me also assuming your carbs arent cut,due to you trying to get bigger.If your protein intake is high and cals above maintanence a bit. (throw in some fiber aswell) you can get a lb-1.5 of muscle by then if done well.Aswell will of course your bench max moving up
Posted 13 April 2012 - 07:43 PM
