Corrupt Pures
Runescape Clan & Community
avatar
Chain
None
Elder
8213
Threads:
1558
RSN:
None
What should of creatine should I buy?
Creatine monohydrate. Plain and simple. No need for any fancy designer creatines. It is proven to work. It is cheap. The typical 200 serving tub will last for will last for at least 3 months.
What exactly does creatine do?
*Provides extra energy for your muscles
*Causes volumization of muscles (just increases the size)
*Reduces lactic acid build up
*Increases protein synthesis
What are the side effects of taking creatine?
There is a possibility of bloating. This, however is temporary and you don't need to worry about it. There have also been anecdotal stories of muscle cramping and dehydration. If you are worried about this, drink an extra litre of water or so, on top of the 4 litres + you should be drinking.
Will I lose my gains when I stop taking creatine?
Creatine generally leads to two types of gains. You can build more muscle due to the added strength creatine can provide and you can retain more water in the muscles. The muscle which you gain as a result of increased strength is the same as all other muscle. It is as permanent as muscle you gain when you don't use creatine. This will not be lost when you stop taking creatine. However, the water retained in the muscle is temporary. This will most likely be lost when you stop taking creatine.
How much creatine should I take each day?
3g - 5g.
What is loading / the loading phase?
Loading is the period of time where you increase your daily dose of creatine to increase the level of creatine in your muscles so that it is available for use. It usually lasts for one week.
How much creatine should I take during the loading phase?
20g - 25g a day, 1 week - 10 days. This amount should be divided into 4 daily servings.
Do I need to load?
No. Loading is probably not needed. However, creatine is cheap. If you want to load to gain any possible benefits of loading then it is fine to do so. Make sure to increase your water intake if you are concerned about dehydration etc.What is the maintenance phase?
This is the rest of the time you spend using creatine. Once you have completed a loading phase, you must keep maintain the levels of creatine in your muscles. This is usually done by taking 3g - 5g a day.
Should I cycle creatine?
It is not known whether it is beneficial or not to cycle long term. Once again I would do so if you are concerned. I'd advise for every month you use creatine, take 2 weeks off, minimum.
What time of the day should I take creatine?
Any time of the day will do. You don't need to take it pre-workout, post-workout, pre-bed or any other important time. All that matters with creatine is that you take it regularly over a long period of time (4 - 12 weeks approx.).
Some people like to take their creatine with their post-workout meal as many people include sugars in this meal which may aid absorption and distribution of creatine.
Will it cause testicle shrinkage?
No.
I am considering using CEE (creatine ethyl ester) or krealkalyn. Do they work?
Read this: http://www.bodybuildingforyou.com/fo…037-post1.html
Useful link: http://forum.bodybuilding.com/showthread.php?t=100831
Can protein supplements be taken with creatine supplements?
Yes. The two supplements are unrelated. Just be aware that some protein supplements contain creatine already (such as Nitrotech and some weight gainers) and extra creatine may not be required.
Quick note:
In my experience, I have never experienced any side effects from creatine supplementation. None of the people who use it who I know have either.
Only consider using creatine when you have a proper diet. You must eat enough calories, protein, carbs and fat a day to gain muscle. If you don't, your body will have nothing to build muscle with. Supplements aid the process but if the process is not happening, they aid nothing and are wasted. GET A DIET.
avatar
Furl
None
Elder
7118
Threads:
72
RSN:
None
the fuck is creatine
avatar
None
Elder
40144
Threads:
2024
RSN:
None
ty 4 this.
avatar
Pat
None
Retired
909
Threads:
122
RSN:
None
Shoulda added where you can get Creatine.
avatar
Humble
None
Retired
1115
Threads:
33
RSN:
None
If you plan on taking creatine, be prepard to drink 2Litres of water EVERYDAY or gf.
avatar
Pink
None
Retired
264
Threads:
38
RSN:
None
Honestly, I've never used Creatine in my life. I know many people on my football team that do.
When I compare using my Whey Protein to using Creatine, I create just as much muscle size…
It provides protein synthesis, meaning you break down proteins faster, helping you build muscle.
In short… I've become stronger by just using whey protein than using creatine. If you want to get started, creatine is great, but when you already have some muscle, I recommend just using whey. No reason to use more money.
avatar
Oneddd
None
Retired
318
Threads:
37
RSN:
None
It's best to use both. Creatine is dirt cheap compared to whey and you'll see better results in both strength and hypertrophy, if you use both. SO USE BOTH. Oh and stock up on Multi-Vitamins like Orange-triad and some Omega 3 Fish Oil pills for maximum results. A strong brain can improve protein synthesis and multis can improve joint strength and do other stuff as well.
avatar
Pink
None
Retired
264
Threads:
38
RSN:
None
omega 3 definitely good point
avatar
Siik
None
Guest
415
Threads:
43
RSN:
None
lol most of my friends use it before they work out
avatar
Toxine
One & Only
Elder
5786
Threads:
586
RSN:
Toxine
creatine worked wonders for me, just got lazy , had no side effects for me though, just keep working if you do creatine other wise you'll just go back to how you were before.
