Guide to 99 Prayer Guilded Altar Method
Hi guys. I have some spare time on my hands today so I thought to myself why not make a 99 prayer guide even though I do not have 99 I only have 95 since that is all I need on my maxed turmoil zerker (Now I Ice U). This is my first guide so go easy on me and leave me tips or correct me if I am wrong.
This guide will contain:
- Level Requirements
- Items needed
- Recommended BoB's
- Some tips
Guilded Altar method (fastest way):
Level Requirements: Level 1 Prayer
Level 75 construction (possible at 69 with boost)
Items you will need are: 2 clean marrentill per round, a tinder box, house tablets and dragon bones or Frost dragon bones. (Frost Dragon Bones are faster exp but will cost you alot more I only recommend if you have a 500M+ bank) =]
A BoB is strongly recommended to hold extra dragon bones.
BoB's you can use are:
Bull ants which requires a level of 40 summoning and can hold 9 items.
Terrorbirds which require level 52 summoning and can hold 12 items.
Tortoises which require a level of 67 summoning and can hold 18 items.
Pack Yaks which require a level of 96 summoning and can hold 30 items. (Pak Yaks bring the most exp per hour)
Set your Summoning button to 'take BoB'
Your inventory should look like this:
http://img602.imageshack.us/img602/9064/invent.png
To make your life alot easier you want to have your Guilded altar close to your entrance portal and you will also want to have your amulet of glory in the next room. Using your own Amulet of Glory in your house will save you more cash then using Duelling Rings. Have your roofs turned of. Just like this:
http://img600.imageshack.us/img600/7682/housez.png
Now teletab to your house. Have your house settings so when you teleport to your house you teleport inside this can be done in the options tab.
http://img593.imageshack.us/img593/3197/teleopt.png
Once you are inside your house light your 2 burners. Then use your bones on your altar select the x option and type in the amount of bones you are carrying or more. Once you have done that you can click on 'Take BoB" and you will keep offering. (If you use offer all it only uses the bones that are in your inventory) I am not quite sure anymore if you just do offer all with the new layout of the skilling if it will do your BoB also since I got 95 prayer before the update. Once you have finished using your bones click on your Amulet of Glory that is inside your house and teleport back to Edgeville.
http://img337.imageshack.us/img337/7025/glory.png
Once you have teleported to Edgevill simply bank and withdraw 2 more clean marrentills and some dragon bones.
Also a tip is to have your x amount of a item set as 2 so you can withdraw your clean marrentills quickly and then withdraw all dragon bones and repeat.
http://img811.imageshack.us/img811/4553/edgeu.pnghttp://img294.imageshack.us/img294/214/bankw.png
99 prayer costs around 270M these days using this method with dragon bones. If you do not want or do not have 75 construction you can always go to world 31 Yanille and ask for a house. Using this method can get you around 220k exp per hour using a BoB and around 150k without not too sure since it has been a while and you can get 220k+ with frost dragon bones. I never used a BoB since I am only 53 summoning and basicly could not be bothered. http://illiweb.com/fa/i/smiles/icon_razz.gif
Thanks for reading my guide.
