Complete Woodcutting Guide
$Sil3nt
, Oct 24 2011 10:09 PM
Posted 24 October 2011 - 10:09 PM
Woodcutting Guide
. http://www.imagedoll.com/out.php/i3402_wcemote.gif
Woodcutting is one of the most popular skills to train being one of the most popular 99 skill in Runescape. It tends to be a long skill to train but needs little effort to get huge amounts of experience as your character can be chopping Ivy for over 8 Minute and gaining you massive amounts of experience, good for watching TV, films or just relaxing. Woodcutting is one of the more basic of skills but still has a lot of different aspects what i will be showing you in this guide.
Before you start woodcutting read parts 1.0-1.3.
1.0 - Hatchets
Hatchets are used to chop trees down. there are many different types of hatchets each having different woodcutting level to use and and chopping rate. always try to keep to the highest hatchet you can to incress speed.
http://www.imagedoll.com/out.php/i3398_iron.gif Iron - WC Level: 1 - Wield: 1 Attack
http://www.imagedoll.com/out.php/i3401_steel.gif Steel - WC Level: 5 - Wield: 5 Attack
http://www.imagedoll.com/out.php/i3395_black.gif Black - WC Level: 6 - Wield: 10 Attack
http://www.imagedoll.com/out.php/t3399_mithril.gif Mithril - WC Level: 21 - Wield: 20 Attack
http://www.imagedoll.com/out.php/i3394_adamant.gif Adamant - WC Level: 31 - Wield: 30 Attack
http://www.imagedoll.com/out.php/i3400_rune.gif Rune - WC Level: 41 - Wield: 40 Attack
http://www.imagedoll.com/out.php/i3396_dragon.gif Dragon - WC Level: 61 - Wield: 60 Attack
http://www.imagedoll.com/out.php/i3397_infern.gif Inferno Adze* - WC Level: 61 - Wield: 60 Attack
Inferno Adze: To use the Inferno Adze as a hatchet, players needs 61 Woodcutting and 92 Firemaking. To use it as a pick axe, players need 41 Mining and 92 Firemaking. It can also be used as a weapon with 1 Attack and 92 Firemaking and requires Prince in peril and All fired up. The adze will burn 25% of all logs chopped good for willow etc but bad for when your chopping Yew or magics.
Tip: If you can afford the Dragon Hatchet or Inferno Adze you should buy as they are 15% faster than the rune hatchet.
1.1 - Stealing Creation
Stealing Creation is a Mini-game and you can buy Sacred clay and volatile hatchets giving a x2.0-x2.2 Xp Boost from the points you have earned during the game
http://img697.imageshack.us/img697/6439/volatilehatchet.png Sacred clay - WC Level: 40 - Wield: 1 Attack - x2.0 Increased Exp
http://img697.imageshack.us/img697/6439/volatilehatchet.png Volatile clay - WC Level: 40 - Wield: 1 Attack - x2.2 Increased Exp
1.2 - Experience Booster's
The lumber jack clothing can give upto 2.5% Extra woodcutter Experience on all woodcutting activities, can be obtained by playing the Temple Trekking activity. This is not recommended as it will take a lot more time to get than it would be worth.
http://img809.imageshack.us/img809/8248/lumberjacktop.png Lumberjack top + 0.8%
http://img94.imageshack.us/img94/1266/lumberjackboots.png Lumberjack boots + 0.2%
http://img836.imageshack.us/img836/2788/lumberjackhat.png Lumberjack hat + 0.4%
http://img842.imageshack.us/img842/8704/lumberjacklegs.png Lumberjack legs + 0.6%
1.3 - Birds Nests
http://img823.imageshack.us/img823/7624/snestring.pnghttp://img185.imageshack.us/img185/5813/snestseed.pnghttp://img844.imageshack.us/img844/540/snestredegg.png
Birds nest fall off trees as you cut them, thye come from all trees and also ivy, these can have upto 335k of value in them containing Seeds, Ring and Egg for summoning. these are worth keeping as you can crush the nest by using a Pesta and Morta and sell the nest for 6K. Wielding a Strung Rabbits Foot can incresss the chance of getting a nest by upto 50%, very good if you are at ivy alot. Strung Rabbits Foot Requires 29Hunter.
1.4 - Sawmill
Using the sawmill requires 80 woodcutting and a saw. This is a Members only feature and will give you around 50-60k WC Exp P/hour on Large task's.
http://img683.imageshack.us/img683/8113/sawmillno.jpg
(1) Receive a job from the Job Board, You can pick a quick or large job. Quick jobs have a smaller plank requirement,
while having a lot less experience, Around 2K Exp. Large jobs require more, Around 5K Exp Per large job..
(2) Gather logs from the Stack of Logs Shown as (2) on the picture above.
(3) gathering the necessary amount, load them into the conveyor belt hopper (3) in the northeast corner of the area.
(4) Once the logs have been into the conveyor belt, go to (4) and collect your planks. You will receive 2 planks per log
loaded, up to a total of 126 planks. You will need spares for when you make mistakes
(5) Cut your planks on either of the two workbenches to fulfill the job requirements listed in the upper right hand corner.
Keep doing this until you have all the cuts required. (doesn't matter if you have more than you need)
(6) Submit your completed job to the Overseer to receive your experience bonus. Then go to the cart and collect all the
spare Cutswhat you can use for your next job.
Experience for cutting the planks.
Cut Planks Difficulty Experienced Exp. With Crystal Saw Straight x1 Short x1 Long Easy 15 30 Diagonal x2 Diagonal-cut Medium 18 36 Tooth & Grove x1 Tooth-cut x1 Groove-cut Hard 25 50 Curve 1x Curved cut Hard 22 44
2.0 Tree's
Trees can be found all around runescape, cutting different types of trees will give different experience depending on its Required level to cut.
Normal Tree - WC Level: [1] - Exp P/Cut: 25
Achey Tree - WC Level: [1] - Exp P/Cut: 25
Oak Tree - WC Level: [15] - Exp P/Cut: 37.5
Willow Tree - WC Level: [30] - Exp P/Cut: 67.5
Teak Tree - WC Level: [35] - Exp P/Cut: 85
Cursed Willow Roots - WC Level: [37] - Exp P/Cut: 15
Hollow Tree - WC Level: [45] - Exp P/Cut: 82.5
Maple Tree - WC Level: [45] - Exp P/Cut: 100
Maple Tree - WC Level: [45] - Exp P/Cut: 110
Mahogany Tree - WC Level: [50] - Exp P/Cut: 125
Arctic Pine - WC Level: [54] - Exp P/Cut: 140.2
Eucalyptus - WC Level: [58] - Exp P/Cut: 165
Yew Tree - WC Level: [60] - Exp P/Cut: 175
Ivy - WC Level: [68] - Exp P/Cut: 332.5
Magic Tree - WC Level: [75] - Exp P/Cut: 250
Cursed Magic Tree - WC Level: [82]- Exp P/Cut: 275
2.1 Dungeoneering Trees
The following tree can only be cut during Dungeoneering.
Tangle Gum Tree - WC Level: [1] - Exp P/Cut: 35
Sleeping Elm Tree - WC Level: [10] - Exp P/Cut: 60
Blood Spindle Tree - WC Level: [20] - Exp P/Cut: 85
Utuku Tree - WC Level: [30]- Exp P/Cut: 115
Spinebeam Tree - WC Level: [40] - Exp P/Cut: 145
Bovistrangler Tree - WC Level: [50] - Exp P/Cut: 175
Thigat Tree - WC Level: [60]- Exp P/Cut: 210
Corpsethorn Tree - WC Level: [70] - Exp P/Cut: 245
Entgallow Tree - WC Level: [80] - Exp P/Cut: 285
Grave Creeper Tree - WC Level: [90] - Exp P/Cut: 330
3.0 - Locations
It is good to have a good woodcutting spot, this can be helpful for faster banking, more trees nearby etc. i will be giving
examples of the best spots to woodcut and the best bank's to use for the best Xp gain/Cash gain.
_________________________________________________________________________________________________
http://www.imagedoll.com/out.php/i3379_woodcutting-normal-tree.jpghttp://www.imagedoll.com/out.php/i3376_woodcutting-normal-tree-map.jpg
You should cut normal trees until 15 then go onto oak what is into the same spot shown above, you can bank in the Varrock
West bank or take a knife and fletch them into arrow shafts for fletching exp.
http://www.imagedoll.com/out.php/i3380_barb-willow.jpghttp://www.imagedoll.com/out.php/i3381_barb-willow-bank.jpg
You should start to cut Willow trees at level 30 until 68 as willow trees are very fast experience and should be done at
either Draynor village or barbarian out post because both spots are very close to the bank. Dranor village is the best F2P
spot and is ofen over crowded in F2P worlds. Willows are around 30-45k Exp P/Hour.
http://www.imagedoll.com/out.php/i3386_yew-location.jpghttp://www.imagedoll.com/out.php/i3387_yes-map.jpg
Yew trees are very good cash but not good for leveling your woodcut.
http://www.imagedoll.com/out.php/i3382_ivy-spot-pic.jpghttp://www.imagedoll.com/out.php/i3383_ivy-spot.jpg
Cutting Ivy is the fastest Woodcutting Exp in the game being 65-85K exp P/hour but is not very profitable as you do not get
logs with this cut, money is made from Birds nests.There are lots of different Ivy spots all over runescape but the one North
west from falador is the best as it is the least populated spot. Ivy is the best and fastest method to 99 Woodcut and
is highly recommended.
Tip: Watching TV or a DVD is a must reely if you are going to 99, you will spent a lot of time at Ivy and seen as it takes so little effort you can easily do something else to keep you interested.
http://www.imagedoll.com/out.php/i3384_magic-trees.jpghttp://www.imagedoll.com/out.php/i3385_magic-tree.jpg
Magic Trees is the fastest cash method in Woodcutting being upto 200K Per/H, it is recommended that you have above level
90 before woodcutting here because Yew trees would be more beneficial below 90.
4.0 - Quests
The following quests give experience in woodcutting, helpful if you enjoy questing.
As a first resort - 15,000 Exp. in Woodcutting
Back to my roots – 40,000 Exp. in Woodcutting
Within the light – 20,000 Exp. in Woodcutting
Grim tales - 14,000 Exp. in Woodcutting
A void dance – 8,000 Exp. in Woodcutting
Legend’s quest – 7,650 Exp. in Woodcutting
Summer’s end – 5,000 Exp. in Woodcutting
Icthlarin’s Little Helper – 4,000 Exp. in Woodcutting
Eyes of Glouphrie – 2,500 Exp. in Woodcutting
Monk’s Friend – 2,000 Exp. in Woodcutting
Heroes quest – 1,575 Exp. in Woodcutting
The tale of the Muspah – 800 Exp. in Woodcutting
5.0 - The Cape
Can be purchased by the Woodcutting master just a little North from Falador center for 99k. The cape gives amazing deffence bonus and if trimmed gives a +4 Prayer bonus too.
1.0 - Hatchets
1.3 - Birds Nests
1.4 - Sawmill
2.0 Tree's
3.0 - Locations
4.0 - Quests
5.0 - The Cape
Sil3nt
RSN: CP1337696969
Clan: Corrupt Pures
Rank: %Council
Posted 24 October 2011 - 10:37 PM
no ty
When things seem most unclear
You will live in days of fear
But whenever you are here
You are the one to steer
Posted 24 October 2011 - 10:38 PM
Posted 24 October 2011 - 10:41 PM
Posted 24 October 2011 - 10:48 PM
Posted 24 October 2011 - 10:51 PM
i want this cape but cba to get banned
Sil3nt
RSN: CP1337696969
Clan: Corrupt Pures
Rank: %Council
Posted 01 November 2011 - 03:09 PM
swswswwswaggggggg
Posted 01 November 2011 - 03:10 PM
#1 guide
Posted 03 November 2011 - 05:34 PM
