Scorpia is one of the newer bosses that was released alongside the Wilderness Rejuvination. She's a large scorpion located in the new caves of the Deserted Keep (lvl 55-56 wilderness where the scorpions are). Just go in the cave and you'll be in her lair.
http://img2.wikia.nocookie.net/__cb20140313144020/2007scape/images/3/35/Scorpia.png < This is what you want to kill.
A few of Scorpia's drops include:
Odium Shard 3 (Current Value: 6.5m)
Malediction Shard 3 (Current Value: 1.25m)
Dragon Scimitar
Lots of different rune pieces
The best part about this boss is that you can fight it without taking any damage.
If you burst/blitz/barrage this boss and pray against range, you do not get hit. Always carry an antipoison. The minions poison 6 and Scorpia poisons 20.
Set-up is simple.
You can even 1 item this boss.
Here's my basic setup:
You'll want BLITZ runes, not BARRAGE runes. You don't want to accidentally barrage your teammate(s) if they're too close to the boss.
You'll need antipoisons for the reasons stated above.
Lobsters for the small hits you'll take from little scorpions time to time, when Scorpia gets unfrozen, or when you're trying to kill the healers.
Sara sword, dscim, whip, or something of that sort for the healers. They will spawn at half hp and you cannot damage Scorpia until they are dead.
Prayer pots so you can (almost) constantly pray range (and maybe mystic might) while fighting. Also if you pray melee and Scorpia is attacking you, she will drain your prayer.
Ring of Wealth because, well, obvious reasons.
How-to final notes:
I recommend taking a sip of antipoison before entering the lair just so you don't forget and take some damage from poison.
The boss is very easy with high drops, so keep in mind that you are STILL IN MUTLICOMBAT LEVEL-55 WILDERNESS when fighting her. Don't take anything you don't want to lose.
Easy way to return if you die: Spawn in Edgeville or teleport to Paddewa (if on ancients) and use the Edgeville lever. Remember a weapon that can slash webs. You'll get back to the lair in time to loot everything. No doubts.
Enjoy!
--Guide by Glider--
