So your pure is probably 1 def or 3 (Imjuststoned<3) and probably maxed out or close to it. I don't suggest getting 20-25 def if you are an edge pker or not high enough cb. So i will guide you through what lvls you go through before making your pure a big daddy.
If you are maxed 1 def you should already get it
75-79 cb
70 attack
85-90 str
75-85 range
80-94 mage
43-52 prayer
After getting close to those stats or atleast one 99 stat, go ahead and do Nature Spirit and Recruitment drive. (You don't need to do any other quests tha give you little def exp but if you're a quest point whore then go for it!)
After achieving everything about you should be around 83-85ish cb, Pretty good huh?
Once you get those stats and Addy gloves and iniatiate you might want to aim for the following items:Mith Defender,Slayer Helm,Mirror Sheilds, Mystic/Enchanted, studded bodies.
Stats to aim for after 20 defence.
90-100+ cb
85-99 attack
90+ str
90+ range
90+ mage
25 def
70+ pray
The reason being of increasing attack is to gain combat lvls for less likely to get piled in trips and preps. Would you want to pile the 100+ or the 77 cb 1 def pure? We know the answer
Higher prayer lvls will make you last longer in f2p events and also incease some cb lvls.
25 defence increases your cb lvl by alteast 1-2 and can take a little more hits. And wear sexy ass stuff
Items:Infinity Robes and Frog Leather(very sexy gear)
My account for reference <3
