For Today's F2P Prep. vs. TLP, we will be Massing at 5:30 EST / 10:30 GMT. The rules for the Prep are as follows:
30 Defence Cap
Corrupts and Dungeoneering [ON]
Under 90 Combat (Binding):
Anyone and everyone who is under 90 Combat, WILL bind. If you find yourself in this situation and you are above 10 Defence, buy Druidic Robes from the G.E and charge them with FOG Tokens.
http://img269.imageshack.us/img269/4742/120628151817.png
http://img825.imageshack.us/img825/4995/120628152120.png
Above 90 Combat:
Wear your best Defensive gear possible just like you would for our F2P Saturday Pk Trips.
http://img84.imageshack.us/img84/8088/120628152430.png
Reminders:
- Buy Maple/Yew Logs NOW and have a couple hundred in your bank so you can get your HP Boost Percentage before the War starts! All you have to do is use any 5 logs on a fire consecutively and you maximum HPs will raise. (At Clan Wars the only place to light fires is inside the portals, so I suggest doing this inside the White Portal).
- I JUST SPENT 25M ON CORRUPTS, SO I WILL BE DROPPING CORRUPTS DURING OUR MASS. MAKE SURE YOU ARE AT W98 GAMER'S GROTTO AS SOON AS POSSIBLE!
- Take the time now to get your Swanky Boots (from the girl inside the Romeo and Juliet home near Varrock West Bank), your Explorer's Rings (from one of the Diary Advisors in Lumby/Draynor), and your Chef's Hampers (from the Lumby Chef after you have completed all of the Lumbridge Diaries).
Let's get another 40+ pull boys and keep this F2P Prep Streak alive.
