Shortkeys guide [ For fast log inn ] -
7 replies to this topic
Hansis
Hansis
    ༼ つ ◕_◕ ༽つ
    • RSN:Statusupdate
    • IRC:Hansis
If you have a email for your log in name or a really long password i would recommend downloading shortkeys:
Shortkeys types what you want , and you only need to type a simple command like ##2 and it will write it for you.
Example: (the only thing i wrote was ##2)
Download link : http://www.shortkeys.com/download.htm
  • Run the ShortKeys Program.
  • From the program menu click on Options | Preferences | Playback and select the General tab.
  • Click on "Use Prefix Keys" and enter ## for the Prefix Keys. Click "OK" to save and return to the ShortKeys window.
  • Select ShortKeys | Add ShortKey from the main menu.
  • In the box titled Original ShortKey enter the following: test (Please use lower case letters.)
  • Tab to the box labeled Replacement Text.
  • Enter the following: The brown cow jumped over the moon
  • Click on the "Save and Close" button.
  • Run the Windows Notepad program.
  • Place the cursor in the Notepad window and type the following: ##test
  • The ##test will be erased and replaced with the text: The brown cow jumped over the moon
If you have any problems or anything , please refer to this video guide.
Video guide:
Part of the 88 man elder unit that will make cp great again
30v30 champions
I've been using Shortkeys since 2011 and they work perfectly. Started using them to log in recently too and its worth it; just make sure yoyou dont make your username & password something you can accidentally type in and you'll be fine.
When I type:
11 = flash2:C in
22 = flash2:[C]-[O]-[R]-[R]-[U]-[P]-[T]-[I]-[O]-[N]
33 = flash2:Corrupt Pures Pile Here!!
and you can edit it to whatever you want.
Sweet, very useful. :)
Mr Clutch
Mr Clutch
    • RSN:MrPVMClutch
    • IRC:[CP]Clutch
Yea looks dope as f.
http://tldr.me/1331bh4.png
    ESSEX #1
    • RSN:ESSX
    • IRC:[CP]George
Nice nice
BACK IN THE DAY
Sacred
Sacred
    We Are Anonymous
    • RSN:Sacred Brid
    • IRC:[CP]Sacred
Thank you for this it will save mass amounts of endless typing to login.
Six
    Your Dad
    • RSN:Daddy Six
    • IRC:[CP]Six
Thank you I've been trying to figure out a way to set up my own shortkeys, this should help when I decide to do it.
