P2P Prep Gear Guide
20 replies to this topic
Victory
Victory
    Superman
    • RSN:King Victory
    • IRC:[CP]Victory
Keeping this short and simple:
3 Restores for whatever setup : it's the perfect amount
No less than 4  and no more than 7 brews
3-4 Phoenix Necklaces
You NEVER need avas - ur bolts get kept for you.
Mage Gear:
This is pretty much the best gear and you should all be aiming for this.
You can swap the halo for a mitre, top for a ghostly top and the bottoms for the sara robes.
Them 3 are personal preference.
N-Range Gear:
Nig-Range is alot more customisable.
You can bring a god book or a mage's book if you wish.
Bring and archer ring are swappable.
Halo-Bearhead-Robin you can all change about
Climbers-Rangers
the whole point of a nig ranger is being able to do the most damage and tank the most
When thinking about the gear you should really think:
Is this worth the food (for a switch)
don't deviate at all apart from the things i said on the gear and u wont be going wrong
15th June 2014 -
`JD
`JD
    • RSN:JD xD
    • IRC:`JD
solid guide,
if you're not using potatoes/karambwans, pnecks and atleast 6-7 brews do so now.
It's all about tanking
Tuna Potato -> Brew -> Pneck should be on.
SwanZiE
    another you
    • RSN:LOSTBOY74652
    • IRC:[CP]SwanZiE
Nice guide
Might also be worth it to add eating (crab > brew > karambwan, if that still works?)
ez
    No Limit (NLMB)
    • RSN:Teboo
    • IRC:[CP]Teboo
You should know dizz
Saim
Saim
    Def<3
    • RSN:Saim
    • IRC:[Def] Saim
Nice :)
Pure Maulerz:
Feeling lucky?
View PostSwanZiE, on 28 May 2015 - 06:06 PM, said:
Nice guide
Karambwans are useless doe
Nice guide.. ;p
Zack
    • RSN:Focus Teemu
    • IRC:[CP]ZackChips
