NOTE: I will assume you read part 1 of this guide and so if you do not know how to setup the script or use it, refer to part 1.
SCREEN MARKERS
Screen Markers is a program that basically can turn your whole screen into a giant paint program, allowing you mark areas on your screen. We can use this program to mark places on our screen to know exactly where to click without having to guess where we need to click. This can make banking even faster than with just AHK alone. We can also use this to mark certain areas on our screen for things like "Magic Imbue" which I will cover later in the guide to again not have to guess where it is located. Below are pictures of exactly what I am talking about.
Download link is: screenmarker.com
REINDEER HAT
The Reindeer Hat is a gift from the Christmas Event and if you don't have it you'll have to wait till next Christmas to get one. What makes the hat special is its emote drops snow on the ground which then can be interacted with to make snowballs. But if we clicked on the snow to cancel lets say a fishing animation and then quickly clicked back to fishing this would actually speed up EXP rates. The reason this works is because within the fishing animation there is a delay in which you cannot catch another fish. So resetting the animation will allow us to catch fish quicker.
This method could also be used in Hardwood Grove in Karamja but using the tinderbox on the log and quickly clicking back on the tree before actually lighting the log will have the same effect as the reindeer hat but also have the bonus of dropping the logs and not wasting ticks to drop them later on.
MAGIC IMBUE/FLETCHING
Incorporating Magic Imbue or fletching darts/bolts into other skills can boost overall EXP gains while lossing little to no EXP in the main skill you're training. Using Magic Imbue on cooldown which is 12 seconds can give 20k magic EXP/h along with the main skill you're training. Fletching is the same thing although EXP rates depend on how often you can fletch in between ticks on your main skill and which bolt/dart you're making. Skills these are primarily used with are: Hunter, Firemaking, Agility, Thieving, Woodcutting, Farming (during trips) and Mining. NOTE: There are few people I know of that can can imbue/fletch with mining without losing ticks. Unless you're willing to take the time to master it, I'd advise against using these methods with mining.
FIREMAKING WITH SUPERHEATING
It is possible to train firemaking while at the same time magic and smithing all at once. While this method will rate less EXP/h for each individual skill, the combined EXP/h is actually higher because of this. The really only ore that works with this method is gold since it doesn't require a secondary ore like coal to make. Simply, fill your inventory with natures, tinderbox and 13 logs and 13 gold ores. Start by casting superheat and within the animation light your log. Alternate back and forth until you empty your inventory and rinse and repeat.
FIREMAKING WITH KARAMBWANS
Similar to FM with superheating we can replace the ores with karambwans. Karambwans are able to cook in one tick which means if we light a log and quickly cook one karam/log we can light/cook all our logs and karams without any lost ticks. This method is extremely difficult to do and will take some practice to master.
PURPLE SWEETS
This method is extremely wasteful but kind of cool to know. Purple sweets can be used with methods like using a tinderbox on your log to quickly drop it and resume woodcutting to completely remove the initial firemaking animation. Just eat a sweet and quickly use your tinderbox with your log and go back to woodcutting.
4 TICK BARBARIAN FISHING
If you didn't know you can technically barb fish your way to 99 fishing without using any feathers (almost). Similar to 3 tick barb fishing using the reindeer hat or the tree if you're lucky enough to have that spot open, using a knife on the fish and to cut them into Roe's or Offcuts they can be used as bait in place of the feathers. This is an obsolete method in the higher end skilling community as alching the fish will give magic exp and waste less time saving ticks. But cool to know you can get 99 fishing using the fastest method fairly cheap/free.
ANTI-VENOMS
This really isn't a method but more of a heads up that it is quicker to manually create anti-venoms then having them automated.
