Corrupt Pures
________________________________________________________________________________________________
Tanking
* Ph Neck on > Rocktail > Saradomin Brew
* Prayers: Always put Mystic Might on When you're tanking, Quick Pray to Protect from Melee + Mystic Might
* When you're tanking put Black D-Hide Chaps on, Turn Mystic Might on + Protect from Range when you're frozen, If not Frozen Pray Protect from mage and drag
* Staff of Light if you're 75 Attack
* Always bring Mind/Body body
Attacking
* Look for clumps
* Ignore people who just used Staff of Light spec
* When your Target is praying Protect from range, Don't range, but switch you style.
* While attacking someone look for the next pile
* Always look for people without Sol's, with Low HitPoints or people who have smite up, These should be the next or first pile.
* If you need to take a sip Super restore, Drink it while your attacking someone. Don't drink it before you attack someone.
Tactics
* Always be spread properly, Always stay at least 3 square pixels away from the your team, but stick together and stick to same piles calling out - CP "Name of Target".
* Dragon Scimitar
* Quick pray to melee/skin/mystic might
* Always try to bring Magic, Mage wins you the mini.
* Bring Recoils if you can't afford Seers ring
* When Defending, Don't wait for the enemy to attack you, but Attack them as soon as you see them running towards us.
* Use Dragon bolts (e) if you can afford them, Else bring Runite bolts. Never bring Addy/broad bolts or even worse bolts
* Pray smite when you're not being attacked, Ony do this when you know that you're safe. ( always be ready to switch your prayer back to protect prayers )
* Don't clump, when you accidentally clump, Pray Mystig might and Protect from Mage.
* Get used to Hotkeys
Gear
* Wear the gear with the best Magic Defence bonus.
* Get a mages' book if you can afford it.
* Get Overloads If you can afford it.
Example Gear
http://img854.imageshack.us/img854/3862/111011191401.png
Maging
http://img638.imageshack.us/img638/6573/111011191516.png
Ranging
Weapons
Range: Use Rune or Chaotic Crossbow with Dragon Bolts (e), You may also use Onyx Bolts (e), Don't bring a Msb
Melee: Any chaotics, Armadyl GodSword, Dragon Scimitar/Dagger, Don't bring Claws
Mage: Chaotic Staff, Staff of Light Or a master wand. Don't bring an Ancient staff.
Items that you should Never bring
* Accumulator
* Magic Short Bow, Always bring a Crossbow
* Leather Top
How Should your Inventory look like
* 2 or 3 Phoenix Necklaces
* 5 To 8 Saradomin brews (4)
* Melee, Range Potions (4)
* 2 or 3 Super restores Potions (4)
* Weapons and Armour
* Rocktails
Credits to Drunky from CPR
